2/18/2019 10.14.4 Beta (18E194d)
Released today. 2.2.2 works with it. I'm not going to upgrade to 2.3.0 until I know it works with this OS.
Re: 2/18/2019 10.14.4 Beta (18E194d)
By the time that macOS 10.14.4 is released, I expect that Audacity 2.3.1 will be out.
Well with the previous beta I couldn't even run 2.2.2 . So I'm glad to be able to edit podcasts again!
