Aud 2.3.0, Max OSX10.11.6, Recovering files
Help for Audacity on macOS.
DoctorOblivious
Re: Aud 2.3.0, Max OSX10.11.6, Recovering files
Post by DoctorOblivious » Sun Feb 17, 2019 8:46 pm
kozikowski wrote:
Sun Feb 17, 2019 8:44 pm
Just recorded an hour long stereo file from 2 USB mics
How did you do that? Audacity generally only recognizes one "thing" to record from.
Aggregated the 2 USB mics, opened Audacity and recorded in a stereo recording
Screen Shot 2019-02-17 at 3.46.23 PM.png (13.94 KiB) Viewed 206 times
Post by kozikowski » Sun Feb 17, 2019 8:49 pm
This is one Audacity Project or show.
They need to be sitting beside each other and have the same name. Double click the Project Manager AUP file and the Project should open.
Post by steve » Sun Feb 17, 2019 8:51 pm
DoctorOblivious wrote:
Sun Feb 17, 2019 8:45 pm
What do I do in the future to avoid this? I assume just keep the data and aup files separate?
Normally when you save a project, it creates an "AUP" file and a "_data" folder, alongside each other. The "_data" folder contains the audio data, and the "AUP" file contains instructions that tell Audacity what to do with the data.
I'm guessing that you accidentally dragged the AUP file into the "_data" folder. To avoid the problem, don't do that ;)
DoctorOblivious
Post by DoctorOblivious » Sun Feb 17, 2019 8:53 pm
Thank you!!
DoctorOblivious
Post by DoctorOblivious » Sun Feb 17, 2019 8:56 pm
Thank you!!
