Hello, I found some issues in the new Audacity that you may consider for the next update.
This is for Windows 10 – 64 bit version.
1. Sometimes it doesn’t play the track in the selected area by the cursor or selection. It plays in the previous place where the cursor was.
2. The play/stop with the space bar as well as the click for the position of the mouse, it has to be pressed with a Little more time in order to respond. Is not as fast as the previous versions.
3. Not a bug but a complain: some effects take now more time to apply: Example: Limiter, clip fix. In the previous versions, the action was really fast. (I use the same parameters)
Well, That are the issues I just found in this version. I hope it could be fixed soon.
Best,
And Greetings from CDMX
Bugs in 2.3.0 Windows 10- 64bit
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
waxcylinder
Re: Bugs in 2.3.0 Windows 10- 64bit
Very much a bug in 2.3.0 (and a regession on 2.2.2).
And a bug which we have fixed for the next release 2.3.1 - not only fixed but made a little faster than 2.2.2
