File not found mp3
Lloydt
File not found mp3
Post by Lloydt » Thu Feb 07, 2019 3:27 am
I'm using window 10. Audacity 2.3.0 down loaded Lame. In Files (x86) Lame For Audacity. When I Export as MP3 and name file. error File no found/check file name and try again. When I export the little window has MP3 highlighted dark letters. I label the file test and get error. I use no (.) Thanks for your help. Lloyd T
Lloydt
Re: File not found mp3
Post by Lloydt » Fri Feb 08, 2019 2:22 am
I fix it. The problem is Virus protection. Not Audacity, or Lame
Turn off Controlled Folder Access:
Select Start  > Settings .
Choose Update & security  > Windows Defender.
Select Open Windows Defender Security Center.
Select Virus & threat protection, and then choose Virus & threat protection settings.
Under Controlled folder access, Allow an app through controlled Folder access.
+ add an allowed app.
search apps.
Program files (X86) Audacity
Program files (X86) Lame for Audacity
open Audacity and was able to save file in my music.
Thank you for your help. hope this helps others. this is a great service.
Lloyd
