Audio Spectrum from Stereo to Mono
Re: Audio Spectrum from Stereo to Mono
Post by steve » Tue Feb 05, 2019 4:00 pm
KerimF wrote:
Tue Feb 05, 2019 3:49 pm
if I export a wav file, that uses 32-bit float, using the 24-bit encoding, there will be no audible loss of any sort if played by the sound card of my lap.
It won't be "bit perfect", but there will be no audible loss.
24-bit integer has a dynamic range in excess of what even an expensive professional sound card can produce. 32-bit float has even better dynamic range, so you are only "losing" audio information that is too small for your sound card (any sound card) to be aware of.
KerimF
Operating System: Windows 7
Post by KerimF » Tue Feb 05, 2019 6:41 pm
The algorithm, I proposed, turned being a total failure, as shown on the attached wave plot.
I calculated on excel the mono samples from the first stereo 100 samples and plotted the results; M1 by using the conventional addition and M2 by using the one I proposed.
Now, I can have a better sleep :)
