All of a sudden not able to import audio
I was able to import and edit audio for my podcast and now all of a sudden I can't. It won't let me import and someone suggested dropping the file into audacity which only leads to static sounds. Any help would be great.
Re: All of a sudden not able to import audio
Why not? What happens when you try?
Which version of Audacity are you using? (Look in "Help menu > About Audacity")
