Podcast improvement
Podcast improvement
Hello everyone,
I am encountering a recurring sound problem that I can't get rid of. I am not sure why my Rode Mic is picking up this sound. I am using Rode NT-USB Versatile Studio-Quality USB Microphone. I attached a sample.
I would appreciate your advice on how to avoid producing this sound when recording audio podcasts and how to get rid of it once recorded. Since it occurs during the speech, noise reduction did not work.
I really appreciate your help as I haven't been able to find a solution myself.
Thank you!
Nodi
Thank you!
Nodi
- Attachments
- Sound issue sample.wav
- (346.04 KiB) Downloaded 20 times
Re: Podcast improvement
I don't hear anything wrong. Can you describe the sound? Also, you can post up to ten seconds of stereo (two blue waves). Sometimes longer lets us get a better sense of the work.
Hi Koz,
I attached a new sample for your review. It sounds as if I poke microphone, in the middle and end of the sample. I can remove it when I can get hold of the noise, but sometimes it is in the word spoken and I cant clean it.
Thanks a lot for your review and reply.
Nodi
Nodi
- Attachments
- Sample.wav
- (568.55 KiB) Downloaded 15 times
There is one "easy " thing wrong. You're too loud.
View > Show Clipping. That will put thin red lines over all the blue waves that are too loud—that reach all the way to one in either direction. Those are the areas where Audacity stopped accurately following your voice and has distorted sound.
I hear it. There's one pop at 1.6 seconds and two at 2.8 seconds.
Do they appear if you start to record, but don't say anything?
There is an abrupt change, as occurs with skipping, which is a digital-glitch, not a real-world sound.Nodira wrote: ↑Sat Jan 26, 2019 10:58 amI am encountering a recurring sound problem that I can't get rid of. I am not sure why my Rode Mic is picking up this sound. I am using Rode NT-USB Versatile Studio-Quality USB Microphone. I attached a sample.
Sound issue sample.wav (346.04 KiB)
Hi Koz,
Thanks for your reply. No, it only appears when I start talking, not before and only around twice during a 10 minute podcast. So, does it mean that I need to speak more quietly? If so, the podcast is going to be too quiet.
Thank you,
Nodi
Thank you,
Nodi
Thank you, Trebor.
Nodi
Nodi
Hi guys,
Here is another example when recording is not loud, but the sound is still there. Beginning and closer to end.
Thank you,
Nodi
Thank you,
Nodi
- Attachments
- Sample 3.wav
- (194.94 KiB) Downloaded 16 times
I can't hear anything wrong with that one.
All your audio here has a lot of infrasound.
infrasound isn't audible, but can create audible problems when the sound is processed,
so it should be filtered-out with a rumble-filter before any other processing ...
Thank you very much for a very thorough reply.
I will try this.
Have a nice day.
Nodi
I will try this.
Have a nice day.
Nodi
