FOCUSRITE SCARLETT SOLO
[email protected]
Operating System: Windows 7
Post by [email protected] » Fri Jan 18, 2019 4:26 pm
Does anyone know if the Focusrite d2/d3 Bundle Plug-in Bundle will work with Audacity.
I'm running Windows7/64bit
https://www.sweetwater.com/store/detail ... gJYLfD_BwE
Re: FOCUSRITE SCARLETT SOLO
Post by steve » Fri Jan 18, 2019 4:32 pm
I don't think so. The formats they list are:
Mac/PC AAX (Native, DSP), RTAS, TDM, AudioSuite
None of which are supported by Audacity. Looks like they are intended for Pro Tools.
See here for information about plug-ins supported by Audacity on Windows: https://manual.audacityteam.org/man/ins ... ndows.html
[email protected]
Post by [email protected] » Fri Jan 18, 2019 4:39 pm
Steve,
Thanks for the input. I tried uploading Pro Tools First onto my Windows7 and having problems installing it. However Audacity seems to be working quite well for now. Back in the day 2004 I was using ACID PRO 5, Acid planet was sponsored by Song. Not sure what it is now.
As for the Pro Tools First free software that came with the Focusrite scarlett, it will not install, period. It keeps giving me a message to reboot the computer half way thru installation. however this is not for this forum I know. I have gone to pro tools forum and found nothing that I can find.
Thanks
APFocusrite
Post by APFocusrite » Thu Feb 21, 2019 10:48 am
Hello ,
We are sorry to hear about the issues you have had with installing Pro Tools First | Focusrite Creative pack.
Sorry that we had not come across this post until now.
We hope that this issue has been resolved now, but if not here's a few suggestions that may help-
Can I please ask you to follow along to this video that shows how to install and activate this version of Pro Tools First - https://www.youtube.com/watch?v=JWKcOVT ... f&index=14
I would also recommend that you check out the our Red Plugin suite (Red 2 Compressor and Red 3 EQ plugins) we bundle with the Scarletts which you should see listed in your Focusrite account - https://www.youtube.com/watch?v=9vJn0FG ... ex=15&t=0s
If you need any further assistance and are looking for quick help, we recommend contacting our support team directly - https://support.focusrite.com/hc/en-gb/ ... ct-Details
Let us know how it goes.
Thanks
AP
