No audio streams exported when using Export2
Please state:
smartflutist661
Post by smartflutist661 » Fri Jan 11, 2019 7:54 pm
On Ubuntu 18.04, I've compiled the current alpha version (2.3.1, evening of 1/10/19) with mod-script-pipe enabled. I'm able to use almost all of the commands (that I've tried so far) successfully. However, I can't get Export2 to export with sound. I get a file output with the correct name, but a size of only a few hundred bytes (which appears to be the [correct] metadata, as it shows up with mediainfo), and no audio streams. No window appears to show export progress in the program. Using the Export dialog I can successfully export with the same track, name, etc.
Here's the command I'm using:
Code: Select all
Export2: Filename=test.m4a NumChannels=2
Re: No audio streams exported when using Export2
Post by steve » Fri Jan 11, 2019 8:52 pm
Congratulations. :)
Code: Select all
That "should" fail. The filename needs to include the full path, so something like:
Code: Select all
Export2: Filename=/home/smartflutist/Music/test.m4a NumChannels=2
Also, there could be a problem with m4a export, depending on the build of FFmpeg. I'd suggest testing it first with a format that is natively supported by Audacity (such as WAV).
smartflutist661
Post by smartflutist661 » Wed Jan 16, 2019 7:47 pm
Thanks, it helps actually... you know... following the instructions. :D
A bit more testing showed me the issue.
Code: Select all
doesn't fail, it just saves the file wherever you are running Audacity from (of course, I expect there would be potential permissions issues, but not likely to be a problem for self-compiled). However, a previous command de-selected all of the tracks in my project, so the export was doing exactly as I asked and exporting exactly nothing. Adding
Code: Select all
SelAllTracks
or whatever is appropriate before every export is the safe way to do it.
Post by steve » Wed Jan 16, 2019 8:49 pm
Yes, I expect so, though I've not actually tested that on a fully installed version on Linux.
(my test version of 2.3.1 is within my "home" user space.)
:D Glad you found it - that could have kept us going for a while.
