I'm hoping to revive this discussion.
What makes this all very difficult for me is I have over 8,000 mp3s and the majority of them was made to the 128 CBR as mentioned. Otherwise I would just turn down the treble and be happy.
I made a thread about this 2 years ago. But I got busy and was unable to follow through with all the necessary tests. What I ended up doing is just giving up on it. But now it's become more necessary that I figure out what is causing this.
My old thread is here: viewtopic.php?f=48&t=93287&p=314261#p314140
Way back when I started playing around with mp3 files, I noticed that as I lowered the constant bit rate this would happen. 1) The Highs would become a little slurred but the bass for the most part would remain the same or sound lower as the extreme highs would get removed. (That's the best way I know how to describe it)
I've always chosen my CBR by determining how much quality per how much disk space / how easy is it for the mp3 player to load up the file.
I've always liked 128 CBR with Sampling rate : 44.1 KHz.
What I always did is buy the highest quality mp3s from Amazon and then use Audacity to export them to 128 CBR. I'm fully aware that this reduces quality. But on the equipment I run these mp3s on, I never noticed enough of a difference to bother my ears.
Today I worked with the following songs from Chatterbox on Windows 7
Code: Select all
01 - Torque.mp3
02 - Empty.mp3
03 - Fallen.mp3
04 - Spine.mp3
05 - Internal.mp3
06 - Soul Scum.mp3
07 - Divide.mp3
08 - External.mp3
09 - Epignosis.mp3
10 - Sunshine.mp3
I'm using a Sandisk Sansa Clip + running the Rockbox firmware. I reset all the settings back to default. So that the EQs were for sure set to flat. I'm using the Koss UR40 head phones, which is my favorite head phone model that I've used since the early 2000's I also ran this same test in my car, and my car stereo gives me the same effect on my hearing. In fact in my car I needed to lower the treble by a lot to get it to sound like something I would call "normal". What is really odd is I have trouble telling the difference in sound quality on the computers using the same head phones I use with my mp3 player. But I don't think that is saying anything. Often times computers have access to better codecs. Where as your mp3 players, you are pretty much stuck with whatever happens to be in the firmware.
In my last thread I was asked about the lame versions.
Linux Mint 18.3
Code: Select all
Version 3.99.5+repack1-9build1 (xenial)
Ubuntu Developers <[email protected]>
Depends: libc6
Depends: libmp3lame0
Depends: libsndfile1
Depends: libtinfo5Code: Select all
I'm running Lame 3.99.3
I do not have FFmpeg installedCode: Select all
Version 7:3.4.4-1~16.04.york0
