Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Quantum
- Operating System: Windows 8 or 8.1
Post
by Quantum » Sun Jan 06, 2019 7:50 am
something is not right
When I activated the Scrub and Seek toolbar....it appeared
in the centre of the screen on a track...and only the top half of the toolbar is visible.
I can't move it, can't do anything with it other than deactivate on the toolbar selection menu. I tried several times - same outcome.
do I have a gremlin again in my computer?.....
Any advice please?
waxcylinder
Post
by waxcylinder » Sun Jan 06, 2019 10:58 am
That will just hide the Scrb toolbar.
You should be able to move the Scrub toolbar to any loaction in either the top or bottom tppldocks by clicking and dragginf on the ruled vertical bar at the left of the toolbar.
See:
https://manual.audacityteam.org/man/cus ... ml#grabber
Quantum
Post
by Quantum » Mon Jan 07, 2019 2:21 am
I tried - can't be moved.
There is clearly something wrong as it shows ONLY the top part of the toolbar which is weird.
Trebor
Post
by Trebor » Mon Jan 07, 2019 11:56 am
Quantum wrote: ↑Mon Jan 07, 2019 2:21 am
... it shows ONLY the top part of the toolbar which is weird.
I've had parts of toolbars disappear when I had two versions of Audacity on my (Windows) computer.
Trebor on Mon Jan 07, 2019 9:06 pm, edited 1 time in total.
waxcylinder
Post
by waxcylinder » Mon Jan 07, 2019 3:41 pm
So
1) Reset Toolbars as Trebor suggests
2 and the restore the Mixer Toolbar from View>Toolbars
