Recording a second track...
jkguinn
Post by jkguinn » Thu Dec 27, 2018 3:15 am
importing an MP3 of the music track and trying to record a separate vocal track. When done, however, the music is showing up on the vocal track? Am I missing a setting or something? Thanks in advance.
Kenny
Re: Recording a second track...
Post by steve » Thu Dec 27, 2018 10:21 am
Which version of Windows?
Which version of Audacity? (look in "Help > About Audacity")
What sort of mic?
How is the mic connected to your computer?
Which recording device have you selected in the device toolbar?
vitagoni
Operating System: Windows 7
Post by vitagoni » Thu Dec 27, 2018 9:38 pm
Your sound card mixes out stream with in stream.. you should search for a button to turn off the mixer on the sound card.
jkguinn
Post by jkguinn » Fri Dec 28, 2018 1:22 am
Which version of Windows? WINDOWS 10
Which version of Audacity? (look in "Help > About Audacity") 2.3.0
What sort of mic? Shure
How is the mic connected to your computer? Mic is connected thru the mixer
Selected USB/Line
Here's a pic of the Behringer mixer, with the Behringer interface connected.
tomtt2
Post by tomtt2 » Fri Dec 28, 2018 1:52 pm
If you hear the first track when recording the new track, then that first track will be recorded onto your new track.
One way around this is to use a headset to listen to the first track while you record the new track.
I've gone as far as playing the first track in a non-Audacity media player and listen on my headset while recording the new track. Once finished, I import the first track into audacity so I have both the first and new tracks in separate tracks with no bleed over. That allows detailed balancing between the two to create the final track. There may be some slight "latency" issues between the two tracks, depending on your setup, but you can offset the first track from the second to compensate.
It is possible in the Audacity "Preferences", to un-click the two play through options so the first track is not heard while recording, but that sort of defeats the purpose since you can't hear the first track.
