m4a No Longer Supported by Audacity
roy.axford
Post by roy.axford » Sun Dec 23, 2018 12:57 pm
When did Audacity end support of m4a files?
None of the published methods for getting Audacity to import m4a files work any longer.
I am forced to use someone else's software.
Re: m4a No Longer Supported by Audacity
Post by steve » Sun Dec 23, 2018 1:14 pm
M4A is a "container format" and may contain any number of audio, video, and even subtitle streams (https://en.wikipedia.org/wiki/MPEG-4_Part_14 and https://en.wikipedia.org/wiki/Digital_container_format). M4A also supports DRM (https://en.wikipedia.org/wiki/Digital_rights_management)
Audacity does not support DRM (never has, and probably never will).
Most other M4A audio files are supported by Audacity if FFmpeg is installed (see: https://manual.audacityteam.org/man/faq ... tml#ffdown)
