Auto recording, auto name, repeat
Anything you think is missing, or needs enhancement, goes here.
cablehead
Operating System: Windows 7
Post by cablehead » Fri Dec 21, 2018 7:37 pm
Greetings,
I have a project where the steps are as follows:
We wait approx 5 seconds for loud sound to quiet down;
then record 30 seconds; save audio file. Then wait approx 45 seconds for loud sound to settle down and continue.
We do this anywhere from 100-300 station stops.
Looking for a plugin or help in automating this procedure; where the software will;
wait until sound is below a db level (as opposed to above), auto save each station uniquely .
Any suggestions or direction appreciated.
Thanks
Re: Auto recording, auto name, repeat
Post by steve » Sun Dec 23, 2018 12:08 pm
the software will;
Audacity can't do that.
You could record the whole thing, then delete the parts that you don't want, otherwise I think you need to look for different software.
anahuj
Post by anahuj » Tue Dec 25, 2018 9:45 pm
Cannot be done with Nyquist? In real-time? As post processing the entire recording?
Earlier I have requested for a second script system because I have kept Nyquist pure flow system. Why Nyquist cannot be used in this application?
Post by steve » Tue Dec 25, 2018 11:11 pm
I expect it would be possible to export the "not loud" parts as separate files, but NOT in real-time, only AFTER the recording is completed.
