Issue with the 2.3.0 version
I deleted the new version (2.3.0) because of issues. Particularly when recording through the PC: the sound was horrible, the recording didn't start automaticaly. So I installed the former version (2.1.0) that satisfy me
Re: Issue with the 2.3.0 version
but you wrote here that you fixed the problem (which was "user error"): viewtopic.php?p=285819#p285819
