UPDATE
Ok, for any audiobook narrators who comes to this thread in the future, I was able to get this to work a different way.
What I did was get a button app for the iPhone http://keypad.iosproapps.com/support/co ... s-windows/
And then, i just created one button on the iphone. Such that, when i push this button, it sends the key "p" to my computer
(You can set the delay on this button if it sends too many "p"'s)
good luck all
Keyboard Shortcut to FORCE a Pause event?
Re: Keyboard Shortcut to FORCE a Pause event?
On Windows there is a thing called FilterKeys , other operating-systems have similar de-bounce keyboard settings.
