Can we move tracks up or down, or change their colors?
LeeX
Post by LeeX » Sun Dec 16, 2018 6:08 pm
Hi,
Can some one please let me know, with Windows version 2.3.0, can we:
(1) move tracks up or down?
(2) change color from blue to different color for tracks?
With these two features, we can keep tracks under edit close to each other, and identify them easily when edit multiple tracks.
Thanks & regards,
Lee
Re: Can we move tracks up or down, or change their colors?
Post by steve » Sun Dec 16, 2018 6:43 pm
Yes, just click on the track's info panel (left end of the track) and drag up/down.
or,
use the commands in the track context menu - see: https://manual.audacityteam.org/man/aud ... _menu.html
Yes. Select from the "Wave Color" options in the track context menu (same place: https://manual.audacityteam.org/man/aud ... _menu.html)
LeeX
Post by LeeX » Sun Dec 16, 2018 11:13 pm
Thanks for the information, Steve.
It works well.
Regards,
Lee
