Saved FLAC files increase in size
I've noticed now a few times that when I edit a FLAC file in Audacity 2.3.0 and export it back to FLAC, the resulting file is considerably larger than the original file. The difference is as much as 10%. It's not due to different compression levels and it's not due to different FLAC versions. I can take the original FLAC file and re-encode it to FLAC using foobar2000 and the size barely changes. Audacity is doing something that results in its saved FLAC files being larger. Any idea what might be going on? Thanks.
Here is the difference in size: "Audacity Commandline FLAC 1.3.2" uses this command line:
"C:\Program Files (x86)\Codecs\flac-1.3.2\win64\flac.exe" --no-seektable - -o "%f.flac" -f
Re: Saved FLAC files increase in size
For "Audacity Commandline FLAC 1.3.2", you're definitely using compression level 5 because that's what flac.exe uses it's given a parameter to override it ("-#", where "#" is the compression level, ranging from 0 to 8). For the others, it's very likely that Audacity is also using 5, while Foobar2000 is using a higher value. Can you double-check which levels you're actually using?
Another thing that may be contributing the file size is the (generally inaudible) noise that Audacity adds for dithering. Here's an explanation on this:
https://alphamanual.audacityteam.org/ma ... xplanation
Even noise this quiet will make the audio harder to compress losslessly, which increases the file size. This, combined with possibly using a lower compression level than what was used for the original file, may explain your situation.
If you want to turn off dithering, simply go to Edit -> Preferences... -> Quality, and in the "High-quality Conversion" section, set "Dither" to "None".
Well, it's the dither making the difference. Turned it off and file size is maintained. Thanks for helping with this.
Since I'm opening 16/44 and saving back to the same, there's no point in dither (right?) I've never noticed it to be audible, but size-wise its impact is much larger than I'd have thought. Maybe because this track is classical and there is a lot of silence?
I'd think the default setting for dither would be "Off" except in cases of higher wordlength being saved to lower. Maybe that isn't possible with Audacity code today, but would be nice for a future release.
Nice try.Since I'm opening 16/44 and saving back to the same, there's no point in dither (right?)
Audacity works internally at 32-bit floating. Not 16-bit. There is always a serious conversion even if you do nothing. Getting into Audacity is a snap since the quality inside is much greater than the quality outside. But Exporting a new show can cause problems.
Any change to the sound during editing can cause errors to "line up" and be audible during export.
Nobody cares about one sampling point quantizing error, but if three or more of them line up, that's audible distortion.
That's a recipe for complaints of "mystery" errors and distortion for normal production.I'd think the default setting for dither would be "Off"...
Thanks, I'd forgotten this.
Not quite.kozikowski wrote: ↑Mon Dec 17, 2018 5:34 pmThere is always a serious conversion even if you do nothing.
If you literally do nothing other than import and export, and the audio files (original and copy) are both in a lossless format (such as WAV or FLAC), then by turning dither off, the output file will be a bit-perfect copy of the original.
Well there's the thing - in the vast majority of cases, people are using Audacity (an "audio editor") to modify the audio before exporting it. If sample values are modified by applying any kind of effect, mixing, pan or gain change, fades, normalizing ... then the (32-bit float) sample values in Audacity will not convert exactly to 16-bit values. This is what "dither" is for. Dither provides a better way of "rounding" high bit formats to lower bit formats.kozikowski wrote: ↑Mon Dec 17, 2018 5:34 pmI'd think the default setting for dither would be "Off"...
Understood. In this particular case, I was simply chopping off a few seconds of silence at the head of a FLAC file. Pretty sure the dither added by Audacity would be of no benefit in this case.
Correct.
As you suggested in your previous post, the way that Audacity handles dither is not ideal in all cases, but making it "ideal for all cases" is a rather complex task (and a "theoretic ideal" may not always be a "practical ideal").
Yes, but it's still converting. It's just under those conditions, the errors go away.If you literally do nothing other than import and export ... the output file will be a bit-perfect copy of the original.
