Recently updated, unable to record anything
Help for Audacity on macOS.
SGCben
Post by SGCben » Mon Dec 10, 2018 6:03 pm
I have recently update audacity, previous version worked fine, but now nothing is recording. My input devices, audio interfaces, are being detected by the software but when I hit record and test the mic, nothing is recorded. I even have tried the internal mic on the mac and still nothing. Can anyone help me here, what am I missing?
billw58
Re: Recently updated, unable to record anything
Post by billw58 » Mon Dec 10, 2018 6:42 pm
Are you using macOS 10.14 (Mojave)? If so, go to System Preferences > Security and Privacy and make sure Audacity has permission to use the built-in microphone.
-- Bill
jeffs11375
Post by jeffs11375 » Sun Jan 06, 2019 8:12 am
I am having the same problem with Mojave 10.14 and Audacity 2.3. Audacity says that it recognizes my microphone, I have updated my privacy settings to allow Audacity access to my mic but it still does not record.
This is what it looks like when I try to record.
Screen Shot 2019-01-06 at 3.11.02 AM.png (289.48 KiB) Viewed 133 times
jeffs11375
Post by jeffs11375 » Sun Jan 06, 2019 10:46 pm
As it turns out the problem was with my microphone. It doesn't work on anything. I've got a new one on order so hopefully that will alleviate the problem.
