How do you make a music track sound better that had to use a microphone to record from the speakers?
joshblaize
Post by joshblaize » Wed Dec 05, 2018 12:51 am
I am using Audacity version 2.0.6 on a Windows 7 computer and a Windows 10 computer.
How do you make an indirect recording music track sound like a direct recording that had to use a microphone to record from the speakers? I want the recording to sound like it did not have to use a microphone to record from the speakers. Any effects or techniques that can do this?
Here's an indirect recording example: (Using a microphone to record off the speakers)
https://www.youtube.com/watch?v=KB4uwITfl6w
Here's a direct recording example: (Using RCA cables)
https://www.youtube.com/watch?v=sEU87jZBm3c
I want the indirect recording to sound like the direct recording. Making a microphone recording sound like it used RCA cable jacks. Any ideas? Cuase, I don't own this Casio SK-5 keyboard. I wish I did have this Casio SK-5 keyboard.
Trebor
Re: How do you make a music track sound better that had to use a microphone to record from the speakers?
Post by Trebor » Wed Dec 05, 2018 1:42 am
It's possible to make a normal recording sound like it was in a bathroom ...
barthroom preset in Audacity's native reverb effect.png (22.51 KiB) Viewed 220 times
https://manual.audacityteam.org/man/reverb.html
But not the other way around.
joshblaize
Post by joshblaize » Wed Dec 05, 2018 7:50 am
Thanks. I'll give it a try.
Trebor
Post by Trebor » Wed Dec 05, 2018 8:21 am
The Audacity's reverb-effect does not remove bathroom reverb, it simulates it.
Removing reverberation is impossible.
