Saving (exporting) to non-Wav is needlessly tedious
Re: Saving (exporting) to non-Wav is needlessly tedious
Post by steve » Tue Dec 04, 2018 3:29 pm
tcmullet wrote:
Tue Dec 04, 2018 2:43 pm
How do YOU suggest I avoid the tedium I described?
There's a number of issues here, so I'll try to answer that question for each case.
Example: You have a .wav file with a 100-character filename. You merely want to convert it (via Audacity) to MP3.
I wouldn't use Audacity for "merely" converting the file type. I'd use a format converter such as LameDropXP or Foobar2000 (both free applications).
This avoids the unnecessary intermediate conversions from WAV -> Audacity Project (32-bit float format data) -> MP3.
I wouldn't use such extreme length file names. If I need to store information about a file, I'd use metadata (which is what metadata tags are designed for).
Using very long descriptive names poses potential risks of using invalid characters (see: https://docs.microsoft.com/en-us/window ... ing-a-file) or breaking compatibility with other applications that may have additional limitations.
Very long file names are also risky if you ever use devices (such as thumb drives) that often have a maximum length for the full "file path + file name" of around 255 characters.
How do you avoid re-typing the 100-characters OR using W.E. to steal the name outside of Audacity?
As I wrote previously, I would name the project.
In Audacity 2.3.0 and later, it is possible to name the project without saving the project. The easiest way to do this is:
1) Enable "View menu > Extra menus"
2) "Extra menu > Scriptables 1 > Set Project"
3) In the "Set Project" dialog, tick the check box before the "Name" field, and enter the required project name, then click "OK" (see also: https://manual.audacityteam.org/man/ext ... et_project)
tcmullet wrote:
Tue Dec 04, 2018 2:50 pm
SO simple for the programmer to add
Audacity is open source, created and supported by volunteers. Patches are welcome, but I doubt it is as simple as you suggest.
Post by steve » Tue Dec 04, 2018 3:45 pm
tcmullet wrote:
Tue Dec 04, 2018 3:10 pm
Our ubiquitous Notepad (which I use often) does it correctly.
"Ubiquitous Notepad" has a horrible habit of adding ".txt" to the end of file names that should have other file extensions.
If there is a "All files (*.*)" option, then there must also be a robust mechanism to enable the correct file extension to be used. NotePad does not have this, and that is well known for causing problems (which MS still refuse to fix).
Yes it is possible to have a "file type selector" (sets the format of the exported file) AND a "file browser filter" (sets which file types are visible in the browser), but:
a) That would be a "feature request", not a "bug".
b) Doing this is not without a downside. Namely that if the filter is not set correctly, then files that match the type of the file that is about to be exported are invisible (hidden).
The problem is exacerbated by the fact that both MS and Apple hide file extensions by default, so many users are totally unaware of the significance of file extensions.
tcmullet
Post by tcmullet » Tue Dec 04, 2018 3:47 pm
I've done some further tests and it appears that if I load a wav with a long name, then I can rapidly export to one or more formats and it defaults to the same long name but with the target extension. This works fine. I'll have to recreate the scenario where it's not adequate and that dropdown is needed.
tcmullet
Post by tcmullet » Tue Dec 04, 2018 3:56 pm
I may respond to more of what you've said later. (Thank you for your attention.) But this item is something I've been against from day 1. When installing windows (which I don't do much these days), I ALWAYS went to explorer defaults and made extensions to SHOW. Yes, there's an "english" file type, but the name itself should always be completely visible to any user who is working with file names. I disagree with those millionaire's well-intended efforts to shield non-computer users from this essential piece of info, the file extension.
tcmullet
Post by tcmullet » Tue Dec 04, 2018 4:00 pm
"Correct file extension"?? Who's to tell ME what is correct? I create an Avisynth script. I save it with extension .avs as I know that's the extension I need it to have. Pull Notepad's *.* dropdown and save as "myfile.avs". It's MY job to spell "avs" correctly. Bravo to MS for letting ME pick the extension and spell it however the heck I want.
waxcylinder
Post by waxcylinder » Tue Dec 04, 2018 4:19 pm
tcmullet wrote:
Tue Dec 04, 2018 3:03 pm
waxcylinder wrote:
Tue Dec 04, 2018 2:56 pm
Workaround
1) Start saving the project as a WAV
2) select the WAV with the filename you want
3) change the "Save as type" to be, say, FLAC
Then the filename should remain but with the changed extension
Thanks, I'll look into it. But I've never "saved a project" and don't see why I need to. I just work with files. I still hope the developer will add the option to see all file types in that export dialog box. I will start looking for examples and give a screen shot maybe (seeing as it appears I am not believed). I looked at both Wordpad and Word 2003, and they BOTH have that narrow-minded flaw FORCING you to always invent a new filename instead of cloning from a file of a different type. I don't care if it's Microsoft. It wouldn't be the only flaw they've displayed.
WHOOPS I meant
1) Start Exporting the audio as a WAV
3) change the "Save as type" to be, say, FLAC, ogg or whatever
4) Then the filename should remain but with the changed extension
5) Make the Export
Sorry for the confusion :oops:
tcmullet
Post by tcmullet » Tue Dec 04, 2018 4:21 pm
I just checked around my drive. I regular use (and need to use) filenames length 90 (including extension), and *I* know what info I need in the filename. (Often, the name gets propagated to files of numerous types.) I want the name to have it so I don't have to look ANYwhere else. It's called self-documentation and just looking at the name tells me all I need to know WITHOUT opening it in some reader that looks into a file header of some sort. I've done this since W95 came out. Metadata? That sounds like specific file types. Using Win95's long names (to a certain extent) for ANY file type is good practice, as long as you don't bomb various limits or use characters that could cause problems somewhere. And 90 is nowhere near 240 or 255.
tcmullet
Post by tcmullet » Tue Dec 04, 2018 4:27 pm
I was referring to one step of multi, in my Audacity session. I think those apps you mentioned are "batch". I want to see the waveform. Edit it. Save as .wav, then maybe also as flac and/or mp3. Stay in Audacity.
Also, I did figure out how to suppress the conversion of 16-bit to float. (I did not know that for the longest time, the default was float. I stick with 16-bit integer)
tcmullet
Post by tcmullet » Tue Dec 04, 2018 4:30 pm
Yes, I ran into that problem in 1997 when I found that the Novell file server I was accessing had 255 limit INCLUDING full path to the file. As we had many subdirs in our system, I eased back on the long names. 86 really should be short enough to avoid most problems. And I don't often have it that long. But at times I need to, and do.
I still don't grasp (remember) how I got by with 8.3 for so many years!
tcmullet
Post by tcmullet » Tue Dec 04, 2018 4:37 pm
I believe my problem came up when editing a "raw" 4 hour .wav, i did trimming, normalizing, etc. Then saved (exported) back to .wav with a carefully built "long name" (not approaching 240, but way more than 8.3). Then in theory, I should dump my project (I don't need a "project", I just work with a file), reload the new .wav and do my conversions. But reloading the .wav takes a lot of time. I figured "I've got the exact content of the exported .wav IN the editor now, so why not proceed to convert to .flac and also to .mp3 WITHOUT reloading the newly named .wav file? But I want the new .flac and .mp3 files to take on the base name of the new .wav file, not the raw one I last imported.
THIS is why I feel I should be able to see extensions in the export dialog box other than the one I'm exporting to. So that I can clone from the .wav name THERE and manually replace the .wav with .flac.
