Updated to 2.3 and now I can't record what my headphones hear
EighthKX
Post by EighthKX » Sun Dec 02, 2018 3:24 am
Running v2.3 on Win10 and when I try to record my headphones on Windows WASAP it gives me an error code
-9996 or -9997
Thing is, if I record my monitor speakers then it works but not my headphone channel.
Googling this gave me nothing but it records my mic just fine but not my headphone channel.
Re: Updated to 2.3 and now I can't record what my headphones hear
Post by steve » Mon Dec 03, 2018 5:41 pm
How are the "monitor speakers" and "headphones" connected to the computer?
EighthKX
Post by EighthKX » Sat Dec 29, 2018 7:06 am
Monitor speakers are connected by HDMI and headphones are USB.
Post by steve » Sat Dec 29, 2018 2:28 pm
If you are trying to record what is playing on your computer, then you must record from the "loopback" option of the device that is playing the audio. So if you are playing through USB headphones, then you need to set Audacity to record from the headphones loopback.
Robert2
Post by Robert2 » Sat Dec 29, 2018 6:14 pm
I get the following message whenever I set up the headphone rate in the Windows Sound Properties after opening Audacity:
Error opening recording device.
Error code: -9996 Invalid device.
On the other hand, I can use WASAPI recording of the headphones if I set up the headphone rate in the Windows Sound Properties before opening Audacity.
HTH
Robert
