Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Post
by kozikowski » Mon Feb 04, 2019 9:11 pm
This is the publication for Windows.
https://manual.audacityteam.org/man/ins ... ndows.html
downloaded the De-click and de-esser links you posted.
Probably not me. I'm not a fan of those two because of the right-brain gymnastics you need to do to use them.
As always, Export your original performance as a WAV safety backup before you work on it. Please also note that sometimes stiff noise reduction can give boosted harshness, ticking and essing.
Trying to fix a ratty performance in post production is an adventure.
