spectrogram settings
bunny94
Post by bunny94 » Fri Nov 23, 2018 6:08 pm
Hi All
Iv'e downloaded the latest Audacity for windows. I am running windows 7. The Spectrogram setting facility doesn't seem to be active in this version Can anyone help.
Trebor
Re: spectrogram settings
Post by Trebor » Fri Nov 23, 2018 8:30 pm
"spectrogram settings" option in the menu is greyed-out until you change from"waveform" to "spectrogram" display.
Only once you've selected spectrogram can you see/change the spectrogram settings ...
spectrogram settings.gif (501.5 KiB) Viewed 270 times
