can any one please help me i am doing a project and i want to put some echo effects on my singing but i am finding it a bit confuseing can any one help please.....what i want is about 3 or 2 echo efects on my voice, but when i try and entre something it just goes mad lol.....i'm just new to it ...help please...thanks mirrorgirl
promlems with echo in audacity
mirrorgirl
hi
Re: promlems with echo in audacity
I'm having a little trouble reading the pink words, so could you use black for a while? PlzKThnx.
I would use a very simple sound or song until you get the hang of how to set the numbers. I posted a simple piano trill that I use for sound tests. It's at the bottom of this page.
http://www.kozco.com/tech/soundtests.html
I didn't like the default numbers in the echo tool. I had much better results like this:
Select All, Effect, Echo.
Change the first number from 1.000 to .25 (one second to 1/4 second). Then try it again later at .15
The first number represents the size of the room. 1.000 is a really large room like an auditorium. One quarter second is more like a tiny lecture hall. Lower than one tenth second is a large living room.
The second number is the liveness or amount of drapes, carpet, and furniture. Increase the number to take the carpet out little at a time.
The echo effect doesn't work as well as a Delay effect would since you can't enter the number of echoes you want (just like in real life).
I recommend downloading the LADSPA effects pack:
http://audacityteam.org/download/plugins
There is a Delay effect in there that is much more straightforward to use.
