Win 7 x64 sp1 Audacity 2.3.0
I'd like to scan for audio sections above xx db and normalize those down to xx db.
Is there such a function, please?
THANK YOU !!!
Is there a function to ...
DennisTheNewbee
- Operating System: Windows 7
Re: Is there a function to ...
The Limiter effect.
DennisTheNewbee
Thank you both soooo much for your help !
Best Regards,
Dennis
Best Regards,
Dennis
