Failed to disconnect from DDE server
GWARslave119
This happens a whole lot after I exit Audacity...
I'll click through the pop-up and when I run Audacity again, usually it will open fine. Sometimes it will saying another instance of Audacity is already running (even though you can run several) and I'll have to go into Task Manager and force close the .exe. Is there anything I should worry about possibly losing/corrupting/etc ever?
Re: Failed to disconnect from DDE server
Are you using ASIO or ASIO4All ?
GWARslave119
Official releases of Audacity do not support ASIO (or ASIO4ALL), so running Audacity at the same time as an ASIO application (such as FL Studio) may cause conflicts. The only way that I know to completely avoid such conflicts, is to not use ASIO and non-ASIO applications at the same time.
(The reason that Audacity does not ship with ASIO support is due to licensing terms.)
GWARslave119
Sorry for the late reply...I made a short video of an example of it happening even without FL Studio (nothing else I use uses ASIO4All, unless there's a way to view what .dll files Windows has running which I'm not aware of any, haven't looked honestly):steve wrote: ↑Fri Dec 21, 2018 11:02 amOfficial releases of Audacity do not support ASIO (or ASIO4ALL), so running Audacity at the same time as an ASIO application (such as FL Studio) may cause conflicts. The only way that I know to completely avoid such conflicts, is to not use ASIO and non-ASIO applications at the same time.
https://sendvid.com/kx7atcs1
And if you count how many pop-up windows show up, it's more than the number of files that I opened, not sure what that means really
Edit: I searched online and found a Microsoft program called Process Explorer which shows all running processes, including .dll files. Asio4All64.dll shuts off immediately after FL Studio is closed, and doing a search for asio when FL Studio isn't running shows 0 results, so there's no conflict with Asio4All causing this problem...
Unfortunately I'm not able to offer much help.
The problem is occurring due to the "Dynamic Data Exchange Management Library" (DDEML), which is part of the Windows operating system (https://docs.microsoft.com/en-us/window ... -the-ddeml). I've never seen this error myself.
Are you using an official release build of Audacity, or a custom version?
The official release version is Audacity 2.3.0 and is available via the Audacity website: https://www.audacityteam.org/download/windows/
(Obviously we cannot guarantee the authenticity of Audacity obtained from other places).
Made an account to post this.
It happened to me, first time today.
See and I use audacity for sometime now, and it happened first time. Unlike the other times, I multi-selected many files (like 10 clips) and opened them together (rightclick while having selected all of them -> Open)
I didn't do anything with them, just wanted to check the length of each, and then closed them one after another, without keeping any change.
On the last clip I closed, the pop-up happened. Pressing OK only pops up another one exactly like it (see attachment)
And the worse of all is that it cannot shut down with task manager
I do have the official version, downloaded from the link you mentioned. README.txt says I have 2.2.2 version, but posting this to be sure I also didnt have absolutely anything else related open, except Unity? (opened them via unity, but Unity doesn't lock/relate to the clips) Like, I selected them via Unity and opened them, just like I would in a windows explorer, so I highly highly doubt Unity is to blame.
As a fellow coder, I did my best to give you as much info on this peculiar bug, hope this post helps!
Actually lol, as I was about to post this, I spammed OK on the pop-up(s) by pressing Enter like a madman, and at some point no more pop-ups appeared in its place.....
