How does a file become a Project?
Please state:
TexasJim
Post by TexasJim » Sun Nov 18, 2018 2:36 am
I'm using 2.1.2(downloaded today, 11/17/18), after losing days of work. I can Record multiple tracks, Edit, Mix and Render. I can't Save my files, because they're not a Project. If I Export to a File or Folder, I can't reload it as a "Project". Years ago, I used Audacity with ease on Windows. I have had nothing but grief on Linux. How do I make files into a "Project"? The tutorials are vague in this area. Thanks in advance. TexasJIm
Re: How does a file become a Project?
Post by kozikowski » Sun Nov 18, 2018 3:53 am
Audacity Saves Projects and Exports stand-alone sound files.
This is a Project.
The AUP file is a text document that tells Audacity what to do with all the stuff in the _DATA folder of the same name. I'm not aware of any difference between Linux and the other two.
Projects will save your environment and tracks and preferences, etc, etc, but will not save UNDO. Projects will only open in Audacity.
Open a Project by double clicking the AUP file. Open a sound file by Importing it.
I'm not aware of Audacity ever working any different from the above notes.
Post by kozikowski » Sun Nov 18, 2018 3:55 am
TexasJim
Post by TexasJim » Mon Nov 19, 2018 8:27 pm
Thanks for the replies. I can create a music file called Test, Export it to an external folder as a .wav file. In my folder there is a file called Test.wav and another called Test.aup. I open that with Audacity, Edit it and try to save it by using Save Project, but it says I don't have a Project, I have a file. How does a Project happen? Why isn't my file made into a Project? What am I missing? Do I HAVE to have my music in a Project? Can I send my music file direct from my folder to a CD burner? That's not what I really want to do. Any help and guidance is appreciated. TexasJim
Post by kozikowski » Mon Nov 19, 2018 9:48 pm
You should wait for a Linux elf. The versions and issues are different for you.
File > Export should not create an AUP file.
Post by steve » Mon Nov 19, 2018 10:00 pm
On Linux, the easiest way to save an Audacity Project is:
"File menu > Save" and give the project a one word name, preferably no spaces, and definitely no "special" characters (such as punctuation characters).
The underscore character "_" is OK to use.
Numbers and letters (a to z and A to Z) are OK to use.
A good name is: my_project
A bad name is: my / project
TexasJim
Post by TexasJim » Mon Nov 19, 2018 10:58 pm
Thanks. When I finish my recording work, the only Save options on my menu are Save Project, Save Project As, and Save Compressed Project. All three result in an error block that says only Projects can be saved, and I must Export my work, since it's not a Project. ????? Thanks TexasJim
Post by steve » Mon Nov 19, 2018 11:17 pm
I think you are probably misinterpreting the message. What is the full and exact message?
TexasJim
Post by TexasJim » Mon Nov 19, 2018 11:33 pm
Thanks. The box contains, as follows:
WARNING
'SAVE PROJECT' is for an Audacity project, not an audio file.
For an audio file that will open in other apps, use EXPORT
Don't show this warning again.
CANCEL O K
I appreciate your attempts to help. I did this years back with no problems, but everything I do is considered to be a "file", and not a Project.
TexasJim
Post by steve » Tue Nov 20, 2018 12:28 am
Ah, I thought it might be that. It is not telling you that you have done anything wrong (it's not an "error" message), it is just warning you that if you "save" then you will get a "project" and not an ordinary audio file.
Many new users expect to get a normal audio file when they "save", but in fact you get a project. Just click "OK" and it will save the Audacity Project.
The "Don't show this warning again." checkbox tells Audacity to stop showing the warning, so now that you understand the message, it safe to tick that box.
Does that make sense now?
