Audacity 2.3.0 freezing
Help for Audacity on macOS.
Re: Audacity 2.3.0 freezing
Post by steve » Wed Nov 14, 2018 10:07 am
aajax wrote:
Sat Nov 10, 2018 9:18 pm
If the device/cable is the problem, now come I am getting an input level?
Is the USB plug good and tight in the USB socket?
aajax
Post by aajax » Thu Nov 15, 2018 4:05 am
How would I get a good input level if it weren’t?
Post by kozikowski » Thu Nov 15, 2018 10:09 am
No idea why it worked
You got lucky. Everybody knows a digital service is either there or it's not. There is no partial connection or other distortion or damage.
But you can have a perfect digital connection that's not present all the time. That gives you things like a perfect transfer of five minutes of music...until the humidity goes up...on Thursday. You changed the USB cable, but did you change it to a shorter one? That's highly recommended as is changing the USB connection on the computer. A connection on the back is more likely to work than one on the front.
I have a Mini where some of the USB connections will not run a keyboard.
One USB Cable is 6' (2M). If you go over that, Bad Things can happen to the connection. The USB microphone people run into this. A microphone can come with a 9 foot cable, but the microphone doesn't always work with a cable that long.
There's a deep philosophy thing, too. You're going to give the cassette player to your son and grandson, right? No? You're probably really going to transfer all your tape and put the whole thing in the bin. That means you bought trash. Sometimes the player turns to trash a little too early.
Post by steve » Thu Nov 15, 2018 10:58 am
If the plug is a bit loose, or the cable slightly damaged on the inside, you may get USB working some of the time, but not all of the time, or the data could be "mostly" getting through, but sometimes dropping bits (which will corrupt the data). There could be a component in the devices that runs too hot and causes data corruption. There could be a "dry joint" on the circuit board in the device. There are many reasons why intermittent faults can happen with USB devices.
There have been a lot of intermittent problems reported when using "Super USB cassette capture" devices (the same device is badged with a variety of names, including: "Generic", "HooToo", "Lychee", "EZ-Cap" and others).
aajax
Post by aajax » Thu Nov 15, 2018 10:20 pm
Everyone wants to blame the player or the connection, but I confirmed I was getting input to the computer. The software should have been able to record that even if it was noise, no? Oh, and I actually tried with two different devices, so I'm supposed to believe both were bad? I mean, sure, it's possible, but this thing has a 4-star customer rating from hundreds of customers on Amazon. And, I don't know, but if this is a common problem with USB, couldn't Audacity be made a little more fault tolerant?
Post by steve » Thu Nov 15, 2018 10:42 pm
Perhaps you could test the device with other software.
There has been some work in the last couple of versions of Audacity to try and make it more robust against faulty hardware, but that is a very difficult and complex task.
