Incredibly slow import in 2.3.0
ppw1
Post by ppw1 » Tue Nov 06, 2018 12:40 pm
Example:
An 8m:40s long .opus file takes 4 seconds to import in 2.2.2 and 37 seconds to import in 2.3.0.
This is unacceptable. What is going on here?
Windows 10 Pro x64 1803
Re: Incredibly slow import in 2.3.0
Post by steve » Tue Nov 06, 2018 1:35 pm
We had a report like this recently that was caused by their antivirus app scanning the project files before allowing the project to open. Perhaps the same in your case. If this is the problem, the white-listing ".au" files may fix it.
normann1974
Post by normann1974 » Thu Dec 27, 2018 7:43 pm
I've noticed that import through FFMmpeg (e.g. AAC/M4A files) is noticably slower after upgrading to Audacity 2.3.0. Disabling my Antivirus (Avast) does (as expected) not fix this.
Post by steve » Thu Dec 27, 2018 8:03 pm
noticably slower
Is that "a bit slower" or "incredibly slow"? The original post is about a 900% slowdown. Are you writing about the same thing?
normann1974
Post by normann1974 » Fri Dec 28, 2018 3:12 am
Import of 3 minute song (tested with .ogg through FFmpeg):
Audacity 2.2.2: approx. 2 seconds
Audacity 2.3.0: approx. 25 seconds
/Jan
Post by steve » Fri Dec 28, 2018 11:04 am
How are you doing that, and why are you doing that?
waxcylinder
Post by waxcylinder » Fri Dec 28, 2018 1:00 pm
I tested this with importing a one hour AAC (M4A) audio file - and although my results are not as extreme as normann1974 reports, I can confirm that 2.3.0 is indeed slower at that import than 2.3.0. But the good news is that the upcoming 2.3.1 appears to have fixed this and is now even faster than 2.2.2.
2.2.2 15 seconds
2.3.0 82 seconds (5.55 times slower 0 normann1974's is 21.5 times slower)
2.3.1 alpha 9 seconds
I don't recall us ever logging this as a big on our Bugzilla tracker nor doing anything to fix it. The one bug that we did have and have fixed for the upcoming 2.3.1 was that Nyquist effects ran slower in 2,3,0 compared to 2.2.2 and earlier Audacity versions. See: https://bugzilla.audacityteam.org/show_bug.cgi?id=1991
Since this appears to be already fixed I don't propose to log it on Bugzilla (as an already fixed P1 bug) - unless you, Steve, think that I should for completeness.
@normann1974: we should be building Release Candidates for 2.3.1 sometime in January - would you be interested in testing your use case on that?
Peter.
normann1974
Post by normann1974 » Fri Dec 28, 2018 1:13 pm
Audacity is doing that. Preferences -> Libraries -> FFMPEG Import/Export Library.
normann1974
Post by normann1974 » Fri Dec 28, 2018 1:16 pm
2.2.2 15 seconds
I just tried the latest alpha as well. Import of the same file I tested with earlier takes 3 seconds, slightly slower than 2.2.2, but remarkably faster than 2.3.0.
Yes, I could do that if needed. Could someone write the announcement of the RC here or send me an e-mail when I need to do something?
/Jan
Post by steve » Fri Dec 28, 2018 2:09 pm
By default, Audacity uses "liboggvorbis" (not FFmpeg) to import OGG files, though it is possible (but not recommended) to import OGG files with FFmpeg.
To check to see which importer Audacity is using:
1) Launch Audacity (or close and restart Audacity)
2) "Help menu > Diagnostics > Show Log" (https://manual.audacityteam.org/man/hel ... l#show_log)
3) Clear the log.
4) Import an OGG file.
The log will show something like:
Code: Select all
14:03:57: Opening with liboggvorbis
14:03:57: Open(...../untitled.ogg) succeeded
