Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Site Admin
Post
by steve » Thu Feb 04, 2021 11:25 pm
Mac80 wrote: ↑Thu Feb 04, 2021 9:10 pm
Hi im having the same issue with a DJM S11, did you manage to get a resolution to your issue?
Given that you're reply to a very old post I doubt that they will reply.
I think the "right" answer is to use Serato DJ Pro as Serato and the DJM's are designed to work together.
