Audacity Not Recognising Mixer
bertiecorrie
Hello,
I have connected my Pioneer DJM-750 mixer to my MacBook (OS Mojave) via USB.
The mixer driver is on the correct settings, and my laptop is recognising the input, see below.
However, Audacity just isn't recognising the input, see below.
I feel like I've tried everything, at this point I'm thinking it's some stupid simple setting that I've missed somewhere.
Any thoughts what might be the issue?
Cheers
Cheers
Re: Audacity Not Recognising Mixer
Have you given Audacity permission to use recording devices? (see: viewtopic.php?p=357189#p357189)
bertiecorrie
Hi Steve,steve wrote: ↑Mon Nov 05, 2018 4:56 pmHave you given Audacity permission to use recording devices? (see: viewtopic.php?p=357189#p357189)
Yes I have, here's a screenshot.
There was a very similar problem posted a while back. They were also using a USB device, Audacity 2.3.0 and Mojave. (You have not said, but I assume that you are using Audacity 2.3.0 - if not, you can update from: https://www.audacityteam.org/download/mac/)
The problem was eventually resolved, but unfortunately they were not sure which step fixed it. You can find the topic here: viewtopic.php?f=47&t=102044
bertiecorrie
Yes, I recently updated to 2.3.0.steve wrote: ↑Wed Nov 07, 2018 12:19 pmThere was a very similar problem posted a while back. They were also using a USB device, Audacity 2.3.0 and Mojave. (You have not said, but I assume that you are using Audacity 2.3.0 - if not, you can update from: https://www.audacityteam.org/download/mac/)
Thanks, I'll check it out.steve wrote: ↑Wed Nov 07, 2018 12:19 pmThe problem was eventually resolved, but unfortunately they were not sure which step fixed it. You can find the topic here: viewtopic.php?f=47&t=102044
bertiecorrie
I've read through this post a few times. However I'm struggling to find the "Audio Devices" panel. Where can I find this?steve wrote: ↑Wed Nov 07, 2018 12:19 pmThe problem was eventually resolved, but unfortunately they were not sure which step fixed it. You can find the topic here: viewtopic.php?f=47&t=102044
You mean as in this post: viewtopic.php?p=357318#p357318bertiecorrie wrote: ↑Wed Nov 07, 2018 4:31 pmI'm struggling to find the "Audio Devices" panel. Where can I find this?
That's in the macOS Sound settings.
If I recall correctly (I'm not currently on a Mac), you get to it via:
"Apple menu > System Preferences > Sound"
bertiecorrie
Hello Guys,
I bought a new MacBook Pro having Mojave and have the same issue with my pioneer DJMS9. Since there is no option to use the 3.5mm jack on MacBook to record with audacity I tried to use the DJMS9 directly for recording. Plugged with USB C, the MacBook recognizes the mixer and I can select my pioneer in the input window instead of the MacBook internal microphone. But I keep having the same issues: the sound preference window is saying „the selected device has no input control“ and audacity is giving the same error message „9997 Invalide sample rate“.
Any help is highly appreciated since I need to record a lot of music throughout my mixer to audacity.
Thank you
Thank you
Hi im having the same issue with a DJM S11, did you manage to get a resolution to your issue?
