Error: try changing the audio host
Please state:
imfranq
Post by imfranq » Sat Nov 03, 2018 10:49 pm
Hi.
That is mi problem, when i try change the audio host in Edit->preference->Device->Interface, the all option is disabled.
How to change this?
Re: Error: try changing the audio host
Post by steve » Sun Nov 04, 2018 4:36 pm
On most Linux systems, the only host is ALSA.
Which version of Linux?
Which version of Audacity?
