Chris's Dynamic Compressor Won't Enable - Audacity 2.3.0
Makieveli
I am trying to ENABLE Chris's Dynamic Compressor, but it won't stay enabled.
Effect/Add Remove/Enable. After doing that the plugin doesn't enable and just goes back to be disabled.
Plugin was working fine until I upgraded to 2.3.0.
Running 2.3.0 on Mojave 10.14.
Any thoughts?
Any thoughts?
billw58
Re: Chris's Dynamic Compressor Won't Enable - Audacity 2.3.0
Do you have a lot of external plugins enabled? The reason I ask is that one thing we can try is resetting Audacity's plugin registry. You'll have to re-enable your plugins after the reset.
To do that, go to:
~/Library/Application Support/audacity
In that folder, delete the files:
pluginregistry.cfg
pluginsettings.cfg
Start Audacity and see if you can enable "Compress &dynamics 1.2.6"
-- Bill
To do that, go to:
pluginregistry.cfg
pluginsettings.cfg
-- Bill
Makieveli
Thanks.
Tried that. The plugin now shoes as New versus Disabled. I Enable it hit OK, it appears to be processing, then I check to see if it worked and it didn't. It doesn't get added to the menu and goes back as a New plugin.
I have tried this several times with no luck. I am also seeing the "Audacity quit unexpectedly" program crash window come up from time to time when I try to enable this plugin. I have added other plugins without a problem, but this one will not work since the upgrade to 2.3.0.
billw58
Hmmmm ... this is all very strange. I'm running Audacity 2.3.0 on macOS 10.14 and it enables, runs fine, and Audacity doesn't crash.
Two things:
1) where did you get the file? Does it say version 1.2.6 in the Enable Plugins dialog?
2) we could reset all Audacity preferences:
go to ~/Library/Application Support/audacity and delete the file audacity.cfg.
-- Bill
Two things:
-- Bill
Makieveli
I have tried resetting all Audacity preferences and it doesn't help.
The plugin shows simply as "compress" in the dialog.
I got the file here: https://theaudacitytopodcast.com/chriss ... -audacity/
billw58
That's the right version of the plugin, but the installation instructions there are out of date.
The file should be installed in ~/Libarary/Application Support/audacity/Plug-Ins
Is that where it is?
-- Bill
-- Bill
Makieveli
Thanks for the help Bill.
Yes, that is where it was located.
After a lot of troubleshooting, I totally removed every Audacity folder and file and did a complete reinstall. That fixed it.
billw58
Could you tell us what "every Audacity folder and file" means? Did you have an "Audacity" folder inside your Applications folder, and a "Plug-ins" folder inside that? Did the problem go away when you deleted that "Audacity" folder?
I'm trying to get a read on this so we can perhaps help others that have a similar problem.
-- Bill
I got it to work as follows. I using Mac OS X 10.14 and Audacity 2.3.1.
After installing Audacity in the Applications folder, have a look in Applications. You'll see "Audacity" but it doesn't look like a folder. Right mouse click on the Audacity app icon. Choose "Show Package Contents." You will now see a sub-folder named Contents. Go into that, then into "plug-ins." Put compress.ny in there. Open Audacity (or re-open it if you had it open while you put the plug-in file in place), choose the "Effect" menu, then "Add/Remove Plug-ins." Find the plug-in named simply "compress." Make sure it's enabled. After all that, you should see a plug-in named "Compress dynamics 1.2.6" in the Effect menu, possibly at the bottom. And there you go.
I have the same problem. I have Catalina (v. 10.15.7) and Audacity 2.4.2. I try to erase the file you recommended but no luck at all. Can you help me, please? Is there any other way to solve the problem? I've uninstalled Audacity three times.
