Audacity can't open in Endless OS
Please state:
buga123
Operating System: Linux Debian
Post by buga123 » Fri Nov 02, 2018 11:09 am
Hello. I use endless os in my Acer Aspire 3 laptop, I can't open it while I install it. I use Endless os 3.4.8.
When I launch it the terminal say: audacity: error while loading shared libraries: libmp3lame.so.0: cannot open shared object file: No such file or directory
I need help how to fix it.because Audacity is important software for me.
Re: Audacity can't open in Endless OS
Post by steve » Fri Nov 02, 2018 12:47 pm
libmp3lame.so.0 is the optional LAME library and is not part of the Audacity application. It is only required if you want to export from Audacity in MP3 format.
buga123
Post by buga123 » Fri Nov 02, 2018 1:02 pm
But I can't open the app
Post by steve » Fri Nov 02, 2018 1:03 pm
Which version of Audacity, and how did you install it?
buga123
Post by buga123 » Fri Nov 02, 2018 1:06 pm
Screenshot from 2018-11-02 14-05-52.png (245.34 KiB) Viewed 594 times
I don't know which version of Audacity, I installed it in Endless OS App center
Post by steve » Fri Nov 02, 2018 1:12 pm
I think you will need to ask Endless OS support about this. We don't make binaries (executable files) for Linux, and Endless OS installs programs in an unusual way that I am completely unfamiliar with.
If you do manage to get it going, please do write back and let us know what the solution was.
Also, if you need help "using" Audacity (once you have a working version), then we probably can help with those kind of questions.
buga123
Post by buga123 » Fri Nov 02, 2018 1:15 pm
The Endless OS workers are say to write in a audacity forum, that's good. I'm not a programer to fix this
Post by steve » Fri Nov 02, 2018 2:30 pm
I can try, but I'm not sure how much I can help because if Audacity does not launch at all, then that is most likely a problem with the build (the Endless OS App package) rather than with Audacity itself.
What happens if you open a Terminal window and enter the following:
Code: Select all
./audacity
buga123
Post by buga123 » Fri Nov 02, 2018 2:44 pm
bash: ./audacity: No such file or directory
Post by steve » Fri Nov 02, 2018 2:48 pm
Try the same without the "./"
Code: Select all
audacity
