Cannot launch Audacity 2.3.0 in Windows 8 [SOLVED]
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Hi,
when i try to open Audacity in my Windows 8, it gives me the following error:
"The application was unable to start correctly (0xc000007b). Click OK to close the application"
Can you help me to solve this, please?
Re: Cannot launch Audacity 2.3.0 in Windows 8
Is that all it says, or is there additional information?
Audacity requires "Visual C++ Redistributable for Visual Studio 2015 " which may not be present on older Windows systems. You can get it from here: https://www.microsoft.com/en-ie/downloa ... x?id=48145
I have Visual C++ Redistributable for VS 2015 version 14.0.24215.1 installed.steve wrote: ↑Thu Nov 01, 2018 9:53 pmAudacity requires "Visual C++ Redistributable for Visual Studio 2015 " which may not be present on older Windows systems. You can get it from here: https://www.microsoft.com/en-ie/downloa ... x?id=48145
Were you previously using an earlier version of Audacity on this machine? If so, which version?
The only references that I can find to this specific error are with unofficial builds of Audacity. Where did you get Audacity from? (please post a link to the web page).
I downloaded Audacity from the official website: https://www.audacityteam.org/download/windows/
Re: Cannot launch Audacity 2.3.0 in Windows 8 [SOLVED]
I finally solved the problem!
Just uninstalled Microsoft C++ Redistributable VS 2015 and installed it again.
Thanks for the help!
Best regards!
Best regards!
Reason: Closed topic [SOLVED]
