I'm just trying to cut every frequencies in a sample except 100 Hz (maybe 99-101 Hz or 98-102 Hz, that's okay) but the Equaliser always makes a curve (green spline on the screenshot below), causing remaining unwanted frequencies (noise, actually) in the sample.
Can this or another more appropriate function be set to not smooth the equalisation frequency map?
It could be great if there would be an effect providing a frequency cut. For example, using my case:
• Frequency: 100 Hz
• Bandwidth: 3 Hz
=> Result: every frequencies is muted below 99 Hz and above 101 Hz (this is that 3 Hz width)
In practice, of course, it would be also a solution if this green curve could be narrowed by a factor.
Thanks for the great work!
