Audacity does not find the correct device [SOLVED]
Please state:
brunoczim
Operating System: Linux Debian
Post by brunoczim » Wed Oct 31, 2018 5:30 am
I am using Arch Linux with kernel version 4.18.
Audacity version 2.3.0.
I have installed it from Arch Linux repositories.
Audio Device Info gives me:
Code: Select all
Default recording device number: -1
Default playback device number: 0
Device ID: 0
Device name: HDA Intel PCH: HDMI 0 (hw:0,3)
Host name: ALSA
Recording channels: 0
Playback channels: 8
Low Recording Latency: -1.000000
Low Playback Latency: 0.005805
High Recording Latency: -1.000000
High Playback Latency: 0.034830
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 1
Device name: HDA Intel PCH: HDMI 1 (hw:0,7)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 2
Device name: HDA Intel PCH: HDMI 2 (hw:0,8)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 3
Device name: HDA Intel PCH: HDMI 3 (hw:0,9)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 4
Device name: HDA Intel PCH: HDMI 4 (hw:0,10)
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 5
Device name: hdmi
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
No recording device found for 'HDA Intel PCH: HDMI 0 (hw:0,3)'.
Selected playback device: 0 - HDA Intel PCH: HDMI 0 (hw:0,3)
Cannot check mutual sample rates without both devices.
However, if I run
Code: Select all
alsa -l
I get:
Code: Select all
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
The first device reported by aplay seems to be missing in Audacity's report. I believe it is the correct device since:
1. Audacity neither plays nor records with the devices it found
2. PulseAudio (via pavucontrol) names the device it uses as "analog"
How do I proceed?
Re: Audacity does not find the correct device
Post by steve » Wed Oct 31, 2018 8:57 am
The recommended version for Linux is Audacity 2.2.2.
The 2.3.0 release is for Windows / Mac only. (2.3.0 on Linux is classed as "experimental" and has some serious bugs).
No Pulse Audio!
Why is Pulse Audio apparently not running? Did you suspend Pulse when launching Audacity?
brunoczim
Post by brunoczim » Wed Oct 31, 2018 3:00 pm
Alright. Installing 2.2.2 seems to have fixed it for recording. However, Pulse Audio *is* running. If I run
Code: Select all
pulseaudio
I get:
Code: Select all
E: [pulseaudio] pid.c: Daemon already running.
E: [pulseaudio] main.c: pa_pid_file_create() failed.
Post by steve » Wed Oct 31, 2018 3:22 pm
What does the Audio Device Info look like with Audacity 2.2.2?
brunoczim
Post by brunoczim » Fri Nov 02, 2018 3:22 pm
Info on Audacity 2.2.2 is:
Code: Select all
Default recording device number: 0
Default playback device number: 1
Device ID: 0
Device name: HDA Intel PCH: ALC256 Analog (hw:0,0)
Host name: ALSA
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.005805
Low Playback Latency: -1.000000
High Recording Latency: 0.034830
High Playback Latency: -1.000000
Supported Rates:
Device ID: 1
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 2
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 3
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 4
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 5
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 6
Device name: sysdefault
Host name: ALSA
Recording channels: 128
Low Recording Latency: 0.021333
High Recording Latency: 0.021333
Supported Rates:
Device ID: 7
Device name: hdmi
Host name: ALSA
Supported Rates:
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 8
Device name: samplerate
Host name: ALSA
Low Recording Latency: 0.007755
High Recording Latency: 0.023220
Supported Rates:
Device ID: 9
Device name: speexrate
Host name: ALSA
Supported Rates:
Device ID: 10
Device name: speex
Host name: ALSA
Supported Rates:
Device ID: 11
Device name: upmix
Host name: ALSA
Recording channels: 8
Supported Rates:
Device ID: 12
Device name: vdownmix
Host name: ALSA
Recording channels: 6
Supported Rates:
Selected recording device: 0 - HDA Intel PCH: ALC256 Analog (hw:0,0)
Selected playback device: 1 - HDA Intel PCH: HDMI 0 (hw:0,3)
Supported Rates:
    44100
    48000
    96000
    192000
Available mixers:
Available recording sources:
Available playback volumes:
0 - Master:0
1 - Headphone:0
2 - Speaker:0
3 - PCM:0
4 - Mic Boost:0
5 - Internal Mic Boost:0
Recording volume is emulated
Playback volume is native
Btw, Pulse Audio GUI calls the device "analog stereo duplex"
Post by steve » Sat Nov 03, 2018 10:11 am
That device info looks strange. There is still no mention of Pulse, but Audacity is reporting the name of some audio "settings" as if they were "devices". Namely:
Code: Select all
Device ID: 8
Code: Select all
Device ID: 9
Code: Select all
Device ID: 10
Device name: speex
Code: Select all
Device ID: 11
Device name: upmix
Code: Select all
Device ID: 12
What is your output from:
Code: Select all
pactl list
brunoczim
Post by brunoczim » Sun Nov 11, 2018 6:44 am
pactl list results in:
Code: Select all
Module #0
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Lennart Poettering"
		module.description = "Automatically restore the volume/mute state of devices"
		module.version = "12.2"
Module #1
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore profile of cards"
Module #3
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Augment the property sets of streams with additional static information"
Module #4
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "David Henningsson"
		module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect available audio hardware and load matching drivers"
Module #6
	Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
	Usage counter: 1
	Properties:
		module.description = "ALSA Card"
Module #7
	Argument: channels=2
	Usage counter: n/a
	Properties:
		module.description = "Adds JACK sink/source ports when JACK is started"
Module #8
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Tanu Kaskinen"
		module.description = "D-Bus interface"
Module #9
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "ESOUND protocol (UNIX sockets)"
Module #10
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Native protocol (UNIX sockets)"
Module #11
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Sylvain Baubeau"
		module.description = "GSettings Adapter"
Module #12
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the default sink and source"
Module #13
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #14
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Colin Guthrie"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #15
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically set device of streams based on intended roles of devices"
Module #16
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "When a sink/source is idle for too long, suspend it"
Module #17
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each ConsoleKit session of this user"
Module #18
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each login session of this user"
Module #19
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #20
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Mute & cork streams with certain roles while others exist"
Module #21
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect when various filters are desirable"
Module #22
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Load filter sinks automatically when needed"
Module #23
	Argument: display=:0.0
	Usage counter: n/a
	Properties:
		module.description = "X11 credential publisher"
Module #24
	Argument: display=:0.0 session_manager=local/bzim:@/tmp/.ICE-unix/595,unix/bzim:/tmp/.ICE-unix/595
	Usage counter: n/a
	Properties:
		module.description = "X11 session management"
Sink #0
	State: RUNNING
	Description: Built-in Audio Analog Stereo
	Driver: module-alsa-card.c
	Sample Specification: s16le 2ch 44100Hz
	Channel Map: front-left,front-right
	Owner Module: 6
	Mute: no
	Volume: front-left: 16383 /  25% / -36.13 dB,   front-right: 16383 /  25% / -36.13 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
	Latency: 45875 usec, configured 46439 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC256 Analog"
		alsa.id = "ALC256 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		alsa.card_name = "HDA Intel PCH"
		alsa.long_card_name = "HDA Intel PCH at 0xf7320000 irq 130"
		alsa.driver_name = "snd_hda_intel"
		device.bus_path = "pci-0000:00:1f.3"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.vendor.name = "Intel Corporation"
		device.product.id = "9d71"
		device.product.name = "Sunrise Point-LP HD Audio"
		device.form_factor = "internal"
		device.string = "front:0"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Built-in Audio Analog Stereo"
		alsa.mixer_name = "Realtek ALC256"
		alsa.components = "HDA:10ec0256,144dc796,00100002 HDA:8086280b,80860101,00100000"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Ports:
		analog-output-speaker: Speakers (priority: 10000)
		analog-output-headphones: Headphones (priority: 9000, not available)
	Active Port: analog-output-speaker
	Formats:
		pcm
Source #0
	State: IDLE
	Description: Monitor of Built-in Audio Analog Stereo
	Owner Module: 6
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
	Latency: 0 usec, configured 2000000 usec
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		device.description = "Monitor of Built-in Audio Analog Stereo"
		device.class = "monitor"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Formats:
		pcm
Source #1
	State: SUSPENDED
	Owner Module: 6
	Mute: no
	Volume: front-left: 20316 /  31% / -30.52 dB,   front-right: 20316 /  31% / -30.52 dB
	        balance 0.00
	Base Volume: 6554 /  10% / -60.00 dB
	Monitor of Sink: n/a
	Latency: 0 usec, configured 0 usec
	Properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
		analog-input-internal-mic: Internal Microphone (priority: 8900)
		analog-input-mic: Microphone (priority: 8700, not available)
	Active Port: analog-input-internal-mic
	Formats:
		pcm
Sink Input #2
	Driver: protocol-native.c
	Owner Module: 10
	Client: 1
	Sink: 0
	Format: pcm, format.sample_format = "\"s16le\""  format.rate = "44100"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
	Corked: no
	Mute: no
	        balance 0.00
	Buffer Latency: 0 usec
	Sink Latency: 44935 usec
	Resample method: n/a
	Properties:
		media.name = "ALSA Playback"
		application.name = "ALSA plug-in [timidity]"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "32"
		application.process.id = "528"
		application.process.user = "bruno"
		application.process.host = "bzim"
		application.process.binary = "timidity"
		application.language = "C"
		application.process.machine_id = "1f99b08d281b44c5b0baaf6ce437303f"
		module-stream-restore.id = "sink-input-by-application-name:ALSA plug-in [timidity]"
Client #0
	Driver: module-systemd-login.c
	Owner Module: 18
	Properties:
		application.name = "Login Session 2"
		systemd-login.session = "2"
Client #1
	Owner Module: 10
	Properties:
Client #2
	Owner Module: 10
	Properties:
		application.name = "xfwm4"
		window.x11.display = ":0.0"
		window.x11.screen = "0"
		application.process.id = "606"
		application.process.binary = "xfwm4"
		application.language = "en_US.UTF-8"
		application.process.session_id = "2"
Client #3
	Owner Module: 10
	Properties:
		application.name = "xfce4-pulseaudio-plugin"
		application.version = "0.4.1"
		application.id = "org.xfce.pulseaudio-plugin"
		application.icon_name = "multimedia-volume-control"
		application.process.id = "663"
		application.process.binary = "wrapper-2.0"
Client #6
	Driver: module-x11-xsmp.c
	Owner Module: 24
	Properties:
		application.name = "XSMP Session on xfce4-session as 24eb6ba54-a63b-4cd6-9981-266f1276984a"
		xsmp.vendor = "xfce4-session"
		xsmp.client.id = "24eb6ba54-a63b-4cd6-9981-266f1276984a"
Client #267
	Owner Module: 10
	Properties:
		application.name = "AudioIPC Server"
		application.process.id = "21335"
		application.process.binary = "firefox"
		application.icon_name = "firefox"
Client #275
	Owner Module: 10
	Properties:
		application.name = "pactl"
		application.process.id = "4097"
		application.process.binary = "pactl"
Card #0
	Owner Module: 6
	Properties:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
		device.description = "Built-in Audio"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
		output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (priority: 8900, latency offset: 0 usec)
			Properties:
				device.icon_name = "audio-input-microphone"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
		analog-input-mic: Microphone (priority: 8700, latency offset: 0 usec, not available)
			Properties:
		analog-output-speaker: Speakers (priority: 10000, latency offset: 0 usec)
			Properties:
				device.icon_name = "audio-speakers"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (priority: 9000, latency offset: 0 usec, not available)
			Properties:
				device.icon_name = "audio-headphones"
		hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, not available)
			Properties:
				device.icon_name = "video-display"
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
		hdmi-output-1: HDMI / DisplayPort 2 (priority: 5800, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
		hdmi-output-2: HDMI / DisplayPort 3 (priority: 5700, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
		hdmi-output-3: HDMI / DisplayPort 4 (priority: 5600, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
		hdmi-output-4: HDMI / DisplayPort 5 (priority: 5500, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
Post by steve » Sun Nov 11, 2018 5:29 pm
According to that, something is playing through "Built-in Audio Analog Stereo" (Sink #0)
What is playing?
Do you have pavucontrol installed?
brunoczim
Post by brunoczim » Mon Nov 12, 2018 1:03 am
Yes I have pavucontrol installed.
Post by steve » Mon Nov 12, 2018 2:28 am
Try shutting down Timidity and VLC and any other audio applications, then restart Audacity and see if you can record from you laptop's mic and play back through the laptop speakers.
