click removal error
chuckyocum
Operating System: Windows 7
click removal error
Post by chuckyocum » Wed Oct 24, 2018 11:33 pm
When I did a preview of the Audacity click removal of a narration, before running the algorithm, I got this message: "Algorithm not effective on this audio. Nothing changed."
What should I do?
Chuck
Re: click removal error
Post by steve » Thu Oct 25, 2018 12:46 am
Does your recording have clicks that need to be removed?
chuckyocum
Post by chuckyocum » Sat Oct 27, 2018 11:16 pm
Yes, there are clicks.
Post by steve » Sun Oct 28, 2018 10:33 am
Do you know why there are clicks? If you are getting a lot of clicks you should be looking to fix the problem that is causing the clicks.
That message is telling you that the effect was unable to find the clicks. That is not unusual because it is a very simple click detection algorithm and is only effective with certain types of clicks. See these links for alternative ways to deal with clicks:
https://manual.audacityteam.org/man/cli ... _view.html
https://manual.audacityteam.org/man/tut ... iques.html
chuckyocum
Post by chuckyocum » Mon Oct 29, 2018 12:00 am
Thanks!
