OK, that answers one question - it's impossible for Audacity to flog the CPU at 90% on a multi-core machine because currently Audacity can only access one core at a time, so it seems that Audacity is flogging one core at 80%, the Desktop Window Manager is flogging the other core (of your 2 core processor) at 80%, and then 20% across 2 cores for other processes, totalling 90% combined.
As you say, Audacity should not be going much over 20% when it launches, and dwm.exe should normally sit at less than 10% (around 2% on a modern machine), so we need to try and figure out why this is happening.
A some things that come to mind:
1) Virus scanning:
What anti-virus do you use?
Is it fully updated?
Have you tried running a full in-depth scan (preferably one that runs at boot time before Windows starts)? If not, please do so as soon as is convenient (it will probably take several hours to complete).
When you added the ZIP version of Audacity, did you remove the version that was previously installed?
If you've still got the "Audacity 2.3.0 zip" file, go to this page: https://md5file.com/calculator and test the zip file. You should get "SHA-256" result of:
f57b4074a544169311830bb428d1d8fefafceb6a3b0680ae23fa1c5321c05835
2) Graphics drivers:
Check to see when your graphics card drivers were last updated.
3) You mentioned a hard drive problem.
What exactly was the problem, and how did you fix it?
