Audacity 2.all
Please state:
Franzl
Audacity 2.all
Post by Franzl » Wed Oct 17, 2018 10:18 pm
Hallo and hello, to the Audacity team,
I use Audacity with a Steinberg U12 with Ubuntu 18.04 Linux, this combination works great without problems, I use that to do voice analysis.
(Analysis -> draw spectra)
For that it would be very helpful if the window in the spectra can be calculated and displayed larger in order to have a better resolution between 100Hz to 3000Hz.
(Edit -> Settings) Spectra
In this window you can set (example 100Hz-3000Hz) but it does not work.
Unfortunately, my programming skills are too bad to do it myself, it would be great if I could soon have a solution to this need.
Yours sincerely.
Franz Bertels :D
Re: Audacity 2.all
Post by steve » Thu Oct 18, 2018 12:14 am
Make a copy of the track (Select the track then "Ctrl + D" to duplicate)
Resample the duplicate track to 8000 Hz sample rate ("Tracks menu > Resample")
With the 8 kHz track selected, open "Plot Spectrum", and expand the spectrum window to full screen.
The resampled track will have a bandwidth up to 4000 Hz.
Also, experiment with the two "Axis" options (linear or logarithmic) https://manual.audacityteam.org/man/plot_spectrum.html
