Hello Audacity community,
This is the first time I have used Audacity, so apologies in advance if this has been answered before. I couldn't find it by searching the forum, but there were so many irrelevant results matching my search terms that it was hard to sift through them all.
I am trying to generate a 40 Hz sine wave tone, and am following the documentation here:
https://manual.audacityteam.org/man/gen ... .html#tone
However, I am getting an error saying "Value not in range: 1.0000000 to 20.0000000". I am not sure which value it is referring to here, since the only inputs seem to have valid values, per the instructions. I tried changing the duration, in case it needed to be at least one second, but got the same error.
I am using Audacity 2.1.2 on Ubuntu Linux version 16.04. Attached is a screenshot of the error message, with the input parameters that I specified. What am I doing wrong?
Thanks in advance,
-brian
Value not in range error when generating a tone
Please state:
Please state:
- Attachments
- 40HzSineWaveToneError.png (102.82 KiB) Viewed 455 times
Re: Value not in range error when generating a tone
The "project rate" (bottom left corner) is way too low.
Typically it should be set at 44100.
Thanks, that appears to have fixed it. I might have accidentally set the project rate to 40 Hz, since I was trying to generate a 40 Hz tone.
