Does 2.3.0 offer portamento effect?
LeeX
Post by LeeX » Tue Oct 09, 2018 4:57 pm
Hi,
Can some one please let me know which effect can be used to make a single pitch slide from one note to another continuously. For example, slide from a higher note to a lower note to create a kind of sad tune.
Thanks & regards,
Lee
DVDdoug
Forum Crew
Re: Does 2.3.0 offer portamento effect?
Post by DVDdoug » Tue Oct 09, 2018 6:46 pm
You can try Sliding Stretch. But, if you want to apply it note-by-note that's not going to be practical.
LeeX
Post by LeeX » Wed Oct 10, 2018 3:48 am
Thanks for your information. It's what I was looking for, and works fine for me.
Regards,
Lee
