What should I use to get the best WAV file?
I have a client who needs WAV files at 44.1, 24bit. I set these in the preferences, but when exporting 24bit doesn't exist. What do I use? It also seems that when these files are listened to outside of audacity there is more noise? How can I fix this?
Re: What should I use to get the best WAV file?
To export 24-bit WAV with Audacity 2.3.0:
"Export menu > Export Audio..."
then select "WAV (Microsoft) 24-bit PCM" in the "Save as type" dropdown menu
joeymakesmusic
Check out this page in the wiki: https://manual.audacityteam.org/man/exp ... acity.html
You want non-lossy and zero compression. 16-bit works well enough.
except that momstro specifically said that their client needs WAV files at 44.1, 24bit.joeymakesmusic wrote: ↑Fri Oct 12, 2018 6:57 pmYou want non-lossy and zero compression. 16-bit works well enough.
Given that it is easy with Audacity to give the client what they are asking for (as described in my previous post), then I see little reason to not give the client what they want.
