How to continue playing from newly set cursor position without stopping playback
When it's playing, if I click on another point of track it sets cursor position to there, but continues playing from where it was. What I want is to continue playing but from the point I just clicked on track, without stopping playback. Is there any way to do this? It is the default behaviour on other DAW I use on windows, and I think it is a sensible way for a DAW to behave.
waxcylinder
Re: How to continue playing from newly set cursor position without stopping playback
You need to use Timeline Quickplay.
Try clicking in the Timeline rather than moving the cursor in the waveform.
See: https://manual.audacityteam.org/man/timeline.html#tqp
How didn't I try that before. Although I would prefer the way I explained in the question, I think it will help much. Thanks.
but then you would not be able to make a selection while the track is playing.
