Folder creation problem
Merowinger
Post by Merowinger » Sat Oct 06, 2018 7:50 am
Hi!
I have this problem for some time and had hoped that it would be fixed in the new version. But it's still here.
1. Drag & Drop a file from a folder on the desktop into Audacity.
2. Work with it, normalize it, export it.
3. Delete / Move the folder with the files
And now the problem: When I use now the "Macro" function, Audacity creates this folder from step 1 again. Without asking. When I delete this folder and use the Macro function again (which I do very often) the folder is there again!
Please fix this.
Re: Folder creation problem
Post by steve » Sat Oct 06, 2018 9:24 pm
I can't follow your description.
I got this far:
1) A folder on my Desktop called "abc"
2) A file in that folder called "music.wav"
3) Launch Audacity
4) Open the folder "abc" and drag the file "music.wav" into Audacity
5) Export from Audacity to create a new file called music2.wav in the Desktop folder "abc"
6) Close Audacity
7) Change the name of the desktop folder from "abc" to "abcd"
8) Launch Audacity again
9) now what?
Merowinger
Post by Merowinger » Sun Oct 07, 2018 6:40 am
When I do that Audacity creates an folder on my desktop from some weeks ago.
Post by steve » Sun Oct 07, 2018 7:56 am
When I do that
When you do what?
Are you saying that if you do steps 1 to 8 as described in my previous post, the folder "Sheet Pan" is created at step 8? :?
Merowinger
Post by Merowinger » Sun Oct 07, 2018 8:02 am
Yes.
It is simple: When I use drag and drop a file from a folder, Audacity is using this folder as default and when I delete it und use the Macro function Audacity creates this folder again if it not already exists. And this is the problem.
If it helps: maybe I can use a screen capture program and post a video from it?
Post by steve » Sun Oct 07, 2018 8:11 am
So it does not happen with my steps 1 to 8?
Merowinger
Post by Merowinger » Sun Oct 07, 2018 8:22 am
It happens when I use the macro function afterwards, as i wrote in my first post.
Sorry, it's not easy to explain that in english. :(
Look at this video: https://www.dropbox.com/s/i7m0cfuu3ily7 ... y.mp4?dl=0
(The folder "If Your Girl Only Knew" is from yesterday.)
Post by steve » Sun Oct 07, 2018 8:55 am
So the folder "001" is being created when you click on the "files" button in the Macro dialog. Is that correct?
I can't reproduce this on Linux. Perhaps it's a Windows 10 thing.
Merowinger
Post by Merowinger » Sun Oct 07, 2018 8:57 am
Yes, that's it.
waxcylinder
Post by waxcylinder » Sun Oct 07, 2018 9:36 am
Sounds like this bug (or similar to it) that we already have logged: Windows: previously deleted folders are unnecessarily re-created on next Save
See: https://bugzilla.audacityteam.org/show_bug.cgi?id=1899
