Audacity stuttering Dante input
Help for Audacity on macOS.
magnusoverli
Post by magnusoverli » Thu Sep 27, 2018 7:18 am
Hi all!
I am setting up a small voice recording studio with the university I am working for. We already have audio distribution via Dante in place for most of our workflow (video studio, video mixer, Final Cut, ++) and this is working very nicely for us. I am however, unable to get a proper recording when using Audacity.
A brief overview of my current setup:
Mics are connected to a RedNet X2P Dante Preamp. This is connected to a dedicated Cisco switch (as is all other relevant equipment). I can the use Dante Controller to route the signal where I want. On the other end I have a MacBook Pro connected to the same Cisco switch. I can monitor this signal and confirm that it sounds correct from various equipment in the network, for example in FinalCut Pro X. However, when I use Audacity, selecting the Dante Virtual Soundcard as input, the recording (and real time monitoring) are stuttering. It is as if only the first half of every second is being processed. I am attaching a screenshot to illustrate.
I have confirmed that the sample rate is 48kHz around the workflow and that the encoding is set to 24 bits on both the RedNet interface and in Audacity.
If anyone have had similar issues I´d really like to learn what can be done!
Best
Magnus Overli, University of Bergen, Norway
Screen Shot 2018-09-27 at 09.10.52.png (633.49 KiB) Viewed 616 times
Re: Audacity stuttering Dante input
Post by steve » Thu Sep 27, 2018 9:12 am
I don't understand how you got that screenshot. In the device toolbar you have the "number of channels" set to "2 (stereo)", but the recorded track is single channel mono. :?
billw58
Post by billw58 » Thu Sep 27, 2018 7:49 pm
You left out the step where you created the "Aggregate Device" and assigned it to the input. What does the aggregate device consist of?
-- Bill
RobinWhittaker
Operating System: macOS 10.14 Mojave
Post by RobinWhittaker » Wed Jul 08, 2020 11:01 am
Hello Magnus,
Did you find a solution to this ... I am getting the same problem.
Thanks
Robin
RobinWhittaker
Post by RobinWhittaker » Wed Jul 08, 2020 1:19 pm
This seems to be the same stutter rate.
Mac OS 10.14.3 Audacity 2.4.2, have also tried earlier versions of Audacity.
Recording from DVS input works fine with other software, Reaper and Garage Band but not with Audacity.
Screenshot 2020-07-08 at 14.09.59.png (383.76 KiB) Viewed 334 times
Post by steve » Wed Jul 08, 2020 2:01 pm
Is DVS running with a 48kHz sample rate?
