Can't record streaming audio after Windows 10 update
Maxthebaker
Post by Maxthebaker » Sat Sep 22, 2018 5:52 pm
first of all, I'm an older guy and a computer illiterate, but I have been able to do a timer record on some radio shows I like while I'm at work. Last night Windows did an update and now the audio won't record. The monitor doesn't react to the sound and nothing comes through. The sound does come through on the computer's speakers. Any help I can get will be appreciated.
roadsterUK
Re: Can't record streaming audio after Windows 10 update
Post by roadsterUK » Mon Sep 24, 2018 8:09 am
I have just patched Windows 10 up to date but I can't reproduce the problem. Which version of windows 10 and which version of Audacity are you using? Can you select the […]speakers ( loop through) option in the window next to the microphone symbol?
Maxthebaker
Post by Maxthebaker » Tue Sep 25, 2018 3:02 am
I have no idea what I did, but I just started clicking everything next to the microphones and now it works. THANK YOU!!!!!
Post by steve » Tue Sep 25, 2018 8:18 am
Could it have been this: viewtopic.php?f=46&t=100117
