Can't hear audio from file
dig1007
Post by dig1007 » Mon Oct 15, 2007 12:16 am
I can't hear a particular file even though it displays waves to indicate content.
My computer plays other files OK and the speakers are fine.
The needle is moving very slowly also, which is strange.
Thanks.
alatham
Re: Can't hear audio from file
Post by alatham » Mon Oct 15, 2007 6:59 pm
You said your computer plays other files just fine, but you didn't specifically say that Audacity plays sounds just fine. Is that true? I'm guessing it is.
What kind of a file is this that you're importing? The 'needle' will move slowly if you're zoomed out a lot. What kind of scale are you zoomed out to?
