"Save" button in "export" dialogue box is grayed out
This section is now closed
mitchbog
Post by mitchbog » Tue May 26, 2009 12:50 am
When I attempt to export an edited track, the "save" button is grayed out and doesn't allow me to do so.
I go to "File" on the menu bar then "Export" which takes me to the dialogue box asking me to select the audio format. The "save" button at this point is always grayed out.
If anyone can explain what I might be doing wrong I would greatly appreciate it.
Thanks.
Re: "Save" button in "export" dialogue box is grayed out
Post by kozikowski » Tue May 26, 2009 4:13 am
This is after you type the filename, right? Did you do something messy in the filename?
Upper and lower case letters, numbers, underscore and dash only. No other characters can be used. I need my work to survive transit to all three computer platforms, so I don't use spaces either.
my_piano_solo-20090525.wav
mitchbog
Post by mitchbog » Sat May 30, 2009 4:18 am
I did have a space in the file name. Will try removing it. I had to leave this project for a few days but will get back to it tomorrow. Thanks for the advice Koz. I'll let you know if the space was the problem.
Mitchell
Post by kozikowski » Sat May 30, 2009 4:50 am
It's not. Spaces are only a problem if you need to bounce between Windows, Linux and Mac, and do it several times a day. Even at that, they're merely very awkward and do not cause actual damage.
I can get a gray "Save" button in my Audacity 1.2 by trying to put the work in a location where I have no permission to do so, like in "Library."
Try Exporting the work to your own personal Desktop.
Another question. I'm using Mac/Intel/Tiger (OS-X 10.4) and I use Audacity 1.2.5, not 1.2.6. Getting the wrong one here is very common.
If you have Mac/Intel/Leopard (OS-X 10.5, like my laptop), then we should be on Audacity 1.3.7. There are no stable versions of Audacity 1.2 for us.
mitchbog
Post by mitchbog » Sun May 31, 2009 4:07 am
I'm using Audacity version 1.3.6. My OS is 10.4.11. Perhaps that is the problem?
How can I export to my desktop? The save button being grayed out would seem to be preventing me from exporting anywhere.
Mitchell
Post by kozikowski » Sun May 31, 2009 5:20 am
Apple > About This Mac.
Read that to me. Does it say Intel or Power PC?
mitchbog
Post by mitchbog » Mon Jun 01, 2009 4:35 am
Power PC
Mitchell
Post by kozikowski » Mon Jun 01, 2009 5:35 am
Mine is 1.3.7.
File > Export... > Edit Metadata > OK
...which opens one of these two windows. Or at least it does here.
http://www.kozco.com/tech/audacity/ExportSimple.jpg
http://www.kozco.com/tech/audacity/ExportFull.jpg
The bottom one is an expansion of the top one.
Does any of this look familiar?
waxcylinder
Post by waxcylinder » Mon Jun 01, 2009 8:56 am
You have actually Stopped the recording and not just Paused it - if you are in Pause mode then the export button (and many others) will be greyed out.
Post by kozikowski » Mon Jun 01, 2009 9:02 pm
Good catch. Let's see what they have to say.
